Index and match with criteria not working
RAM72
I have a working sheet which extract tax code from database column B as lookup and extract tax rate on column E, however when there is a criteria in COLUMN K,then lookup in database corresponding column M and extract the tax amount, if another criteria in column K then look to the corresponding column and extract the tax amount.
=SUMIF('DATABASE TAX CODE '!B:B,G2,INDEX('DATABASE TAX CODE '!$B$1:$R$6395,,MATCH(IF($K2="",$AA1,$K2),'DATABASE TAX CODE '!$B$1:$R$1,0)))
  • WORKINGS .xlsx
The problem is in this section
If K2 = "" it will lookup "Duty" in which column ?
I think Workings K2: should be
=IF(ISNUMBER(SEARCH("SADC",I2)),"SADC %","")
That still doesn't help with what to do if K2 is blank, as none of the Headings in DB Tax Code are called "Duty"
If K2 =SADC on workings sheet, then lookup column M (SADC%) on TAX database and extract corresponding tax otherwise if K2 is blank, then extract on tax database column E general % corresponding tax.
Hope it helps
