IF FUNCTION HELP
Simon Lee
Hi there
I'm sure this is child's play but I need the formula for this instance:
In the Cell J1 I need the following to happen;
If the letter Y is present in Cell D1 then I need the numerical values in Cells E1, F1, G1 & H1 to be added and then appear in Cell J1.
If the letter N is present in Cell D1 then I need a Zero to appear in Cell J1.
Try as I might I can't find a similar example.
Help :)
Hi Simon,
Welcome to Chandoo.org Forum,
Please enter the below formula in Cell J1 and drag it down till the last row of your data.
=IF($D1="Y",$E1&$F1&$G1&$H1,IF($D1="N",0))
Please let me know if you find problem in the above formula.
Thanks & Regards,
Anupam
Sajan
Hello Simon,
Not sure what you mean by "letter Y is present in cell D1"... if cell D1 can contain a string that may include the letter Y (such as "HAPPY") then, you would want to replace the $D1="Y" with FIND("Y",$D1)
Also, not sure if you wanted the numbers in E1:H1 concatenated or added up. If you want the numbers added, use SUM(E1:H1)
Cheers,
Sajan.
Xiq
Also,
What should happen when lowercase (i.g.: "y" and "n") letters are used? Or more then just Y and N?
Here is my shot at it:
=SUM(--ISNUMBER(FIND({"y";"Y"},D1)))*SUM($E1:$H1)
  • It looks for the letters "y" or "Y" in D1 and sums up E1:H1
  • If neither, then zero
Or here is one if you only could have Y or N in D1:
=(D1="Y")*SUM(E1:H1)
Simon Lee
Ok got another one for you guys.....(and ladies of course :)).
I have a blank cell and I need the formula to put in it that gives me the result of the following query.
Cell A1 is a Y or N value. Cell A2 is a 1 or 0 value. Cell A3 is the Cell I need the result in.
If A1 = Y and A2 = 1 then A3 = 0.5, however If A1 = Y and A2 = 0 then A3=0 as well as if A1 = N and A2 = 1 then A3 = 1, however if A1 = N and A2 = 0 then A3 = 0
Abhijeet R. Joshi
Hi Simon,
I think you will need to open a new thread for this..
However, just my two cents:
=IF(A1&A2="Y1",0.5,IF(OR(A1&A2="N0",A1&A2="Y0"),0,IF(A1&A2="N1",1,"No Match")))
Hope this helps...:)
