I need help with code please!!
I have created a little database file. This has the functionality of searching information(previously set in an table that is in sheet called "Guests". The code I set works perfectly when you search by "Guest Name" and when searching by "Room Number". You can see there are two more TextBoxes in the UserForm. I need that those three TextBoxes(TextBox2, Textbox3 and TextBox4) to display the corresponding data that appears in the ListBox Below. I mean...if I search a name in TextBox1, I want that TextBoxes 2, 3 and 4 to display that data(Room Number, Arrival Date and Departure Date. The same situation must happens if I only search by Room Number(TextBox1, TextBox3 and TextBox4) should display info according to the ListBox1. Can it be done? If it is so, I need to help me how to do it. Thank you very much. I am sending the file attachment and some screenshots for a better understanding of what I need. Also I am attaching the code I used in the Complete UserForm.
Thank you so much.
TextBox1.Value = ""
TextBox2.Value = ""
TextBox3.Value = ""
TextBox4.Value = ""
TextBox1.SetFocus
TextBox1.BackColor = vbWhite
TextBox2.BackColor = vbWhite
TextBox3.BackColor = vbWhite
TextBox4.BackColor = vbWhite
Private Sub CommandButton2_Click()
TextBox1.Value = ""
TextBox2.Value = ""
TextBox3.Value = ""
TextBox4.Value = ""
TextBox1.SetFocus
Private Sub TextBox1_Change()
TextBox1.BackColor = vbCyan
With ListBox1
.List = Sheets("Guests").ListObjects(1).DataBodyRange.Value
    For i = .ListCount - 1 To 0 Step -1
        If Not UCase(.List(i, 0)) Like "*" & UCase(TextBox1) & "*" Then .RemoveItem i
Private Sub Textbox1_Exit(ByVal Cancel As MSForms.ReturnBoolean)
Private Sub TextBox2_Change()
TextBox2.BackColor = vbCyan
With ListBox1
        If Not UCase(.List(i, 1)) Like "*" & UCase(TextBox2) & "*" Then .RemoveItem i
Private Sub Textbox2_Exit(ByVal Cancel As MSForms.ReturnBoolean)
Private Sub TextBox3_Change()
TextBox3.BackColor = vbCyan
Private Sub Textbox3_Exit(ByVal Cancel As MSForms.ReturnBoolean)
Private Sub TextBox4_Change()
TextBox4.BackColor = vbCyan
Private Sub Textbox4_Exit(ByVal Cancel As MSForms.ReturnBoolean)
Private Sub UserForm_initialize()
With Sheets("Guests").ListObjects(1)
ar = .DataBodyRange
    With ListBox1
        .List = ar
        .ColumnCount = 9
        .ColumnWidths = "150;50;50;60;60;63;40;40;40"
  • Guest Search.xlsm
    Guest Search.xlsm
Thank you. You are awesome. It worked. But what happens if I just click on any data from the Listbox below. Could it be possible to do, display the requested information on the Corresponding TextBoxes: TextBox1, TextBox2, TextBox3 and TextBox4?
