I need help for creating hyperlinks.
ThrottleWorks
I have multiple worksheets in my workbook (around 500).
All the sheets are named in a date format.
I have created an index file where hyperlink is provided for each sheet.
The problem I am facing is, the number of sheets are getting increased everyday & I have to create hyperlink for these sheets manually.
Is there any formula or vba code, where I will be able create the hyperlink automatically on the basis of sheets added.
I tried with list box (without VBA) but could get through, please help.
Sachinbizboy
500 sheets in a file ?
I would seriously look to shifting the data to a single sheets or even to an Access or SQL data base
How many records per day ?
Hi Sir,
extremally sorry for the late reply, was busy in other work.
Only 1 sheets gets add per day.
Have a nice week end.... Sir I do not know Access or SQL
Here is some vba code that I have written that creates an "Index Sheet" at the beginning of the workbook.
You could update the code to delete the Index Sheet before it runs each time that way you don't have to manually do it?
Public Sub SheetNames()
'Macro created for Carlyle Coinvest
'Macro by Matt Nuttall
Dim i As Variant
Dim MainWks As Worksheet
Dim r As Long
Dim Wks As Worksheet
Dim x As Long
Dim F As Variant
Worksheets(1).Activate
Worksheets.Add().Name = "Index Sheet"
Worksheets("Index Sheet").Activate
Set MainWks = Worksheets("Index Sheet")
For Each Wks In Worksheets
If Wks.Name <> MainWks.Name Then
r = r + 1
With MainWks
.Hyperlinks.Add Anchor:=.Cells(r, "A"), _
Address:="", _
SubAddress:="'" & Wks.Name & "'!A1", _
TextToDisplay:=Wks.Name
Next Wks
Columns("A:A").Select
Selection.Insert Shift:=xlToRight
Range("A1").Value = 2
Range("A2").Value = 3
With ActiveSheet
x = .Cells(.Rows.Count, "B").End(xlUp).Row
Range("A1:A2").Select
F = Range(Cells(1, ActiveCell.Column), Cells(x, ActiveCell.Column)).Address(False, False)
With Selection
.AutoFill Destination:=Range(F)
Range("A1").CurrentRegion.Copy Range("F1")
Columns("A:B").Select
ActiveWorkbook.Worksheets("Index Sheet").Sort.SortFields.Clear
ActiveWorkbook.Worksheets("Index Sheet").Sort.SortFields.Add Key:=Range( _
"B1:B200"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
xlSortNormal
With ActiveWorkbook.Worksheets("Index Sheet").Sort
.SetRange Range("A1:B200")
.Header = xlNo
.MatchCase = False
.Orientation = xlTopToBottom
.SortMethod = xlPinYin
.Apply
Range("A1").EntireRow.Insert Shift:=xlDown
Range("A4").Value = "Alphabetized"
Range("A5").Value = "Tab Number"
Range("B5").Value = "Sheet Name"
Range("A4:B4").MergeCells = True
Range("F4").Value = "Workbook Order"
Range("F5").Value = "Tab Number"
Range("G5").Value = "Sheet Name"
Range("F4:G4").MergeCells = True
Range("A4:B4,F4:G4").Font.Bold = True
Range("A4:B4,F4:G4").HorizontalAlignment = xlCenter
Range("A5:B5,F5:G5").Font.Underline = xlUnderlineStyleSingle
Range("A1").Select
Range("A1").Value = "Table of Contents"
Range("A1:G2").MergeCells = True
Range("A1:G2").HorizontalAlignment = xlCenter
With Selection.Font
.Name = "Arial"
.Size = 20
With Selection.Interior
.Pattern = xlSolid
.PatternColorIndex = xlAutomatic
.ThemeColor = xlThemeColorLight2
.TintAndShade = 0.599993896298105
.PatternTintAndShade = 0
Columns("A:G").EntireColumn.AutoFit
Range("A1").Select
Good luck.
Hi mnuttall87, thank a lot for the support & your time.
I am trying this, will definately share the results.
Have a nice weekend.
Glad it was useful. Adding in a bit of code to delete the Index Sheet so that you can just run it would probably be beneficial in your scenario it sounds like.
