M monithis New Member Jan 12, 2022 #1 I want to know how to make a vlookup from sheet 1 to sheep 7 using column A to column I (in all of the sheets). All I got is: =vlookup(A2, 'Sheet1:Sheet7'!A:I, 7,0) But I got an error. How do I fix the range between columns and sheets?
AlanSidman Well-Known Member Jan 12, 2022 #2 You will need to build a nested IF-Then-Else statement that includes vlookup for each sheet.
M monithis New Member Jan 12, 2022 #3 AlanSidman said: You will need to build a nested IF-Then-Else statement that includes vlookup for each sheet. Click to expand... How do I do that?
AlanSidman Well-Known Member Jan 13, 2022 #4 VLOOKUP across multiple sheets in Excel with examples Formula examples to Vlookup from another worksheet or workbook, Vlookup in multiple sheets, and indirect Vlookup to dynamically pull data from several worksheets into different cells. www.ablebits.com
