How to use Row label and Column label in Pivot conditional formula
RohanSatha
Hey All,
I have a pivot table with two different date fields in row_label & column_label. I need to do conditional formatting on value cells using row label & column label header as values in formula. I need to know how to refer these two(header) in formula. thanks
Example: = column label > row label
Have attached it for better understanding..
As the column labels will always be in same row, and row labels will be in same column, you should be able to do something like:
=B$3>$A5
If that won't work, perhaps you could give some more detail as to what the layout of the PT is, and/or what you are trying to highlight?
Hey Luke,
Thanks a lot for your concern. I have attached a sample file with the situation in my previous thread.
Rohan.S
