Sebastiandiaz
I know this question sounds a little dumb, but I need to find a way to use the "IF" conditional formula to solve a simple issue. Well, I have a simple excel file. It has two columns, "Value1" and "Value2". I need to find out if the value in column "Value1" is equal to the value in column "Value2" if it is equal, I want that the column "C: C", called "Analogy", to display the symbol "✔", if the value is different, so column "C: C" will show the symbol "". Can it be possible by using the "IF" Formula?
I am attaching my simple file.
Thank you in advance-
