Help with formula to sum totals for unit prices times number of units
Steve P
I am having problems coming up with a solution to this: I have two columns, one with a list of unit prices and one with an x,2x,3x,etc (where "x" is to denote # of units). I am trying to avoid using just a number for # of units, although I realize a simple sumproduct(a:a,b:b) would probably work.
I am stuck because I cannot figure out how to create the formula to correctly sum the total price (units prices * number of corresponding units) WITHOUT using an actual number for the # of units. If you can't already tell, I am trying to build a budget template where a user will use a drop-down (data validation) to select the number of units, and the total cost will be a sum at the bottom of the column. For a better visual, please see below:
Column A Column B
$49 x
$25 2x
$100 x
$325 3x
total cost =WHAT FORMULA to get ((49*1)+(25*2)+ ect...)???
Please help!!
Thanks!
Hi Steve,
You can use a helper column with the following formula :
This will extract the figures before the x and convert it to a number
=IF(FIND("x",C2,1)=1,1,MID(C2,1,FIND("x",C2,1)-1))
You can the use the Sumproduct with the helper column
cheers
kanti
Hi Steve,
I used the worng columns the formula with your columns would be in Column C as follows:
=--IF(FIND("x",B2,1)=1,1,MID(B2,1,FIND("x",B2,1)-1))
note the double negative signd before the IF
Cheers
kanti
Steve
I would go with the numbers without the X's, which will mean you can use a simple Sumproduct formula to get your answer.
You can then use a Custom Number format like # x, #x or #X etc
which will display the numbers as you want them
Custom number formats are better and a faster way to achieve this, since if you achieve to have a high number of row, Excel will spent all its time calculating the helper column ...
Note that they can print too :)
ok... as Cyril or Hui suggest use actual numbers instead of xs. If that doesnt work, try this formula.
=SUMPRODUCT(A1:A10,VALUE(IF(B1:B10="x","1",SUBSTITUTE(B1:B10,"x",""))))
you must press CTRL+SHIFT+ENTER after this.
If somehow you can get 1x instead of just x, then this non-array formula works too,
=SUMPRODUCT(A1:A10,VALUE(SUBSTITUTE(B1:B10,"x","")))
