BL84
Simply put, I need an Excel formula that will replace the Numbers formula. You can see what the Numbers formula does when handicaps are subtracted.
The gray appears due to conditional formatting. The numbers will appear under the "strokes given" heading depending on which handicap is larger. I'm updating
so I can use the formula on both sides of the score card. Formula must be slightly different for Excel. The Numbers sheet has the formula listed.
The handicaps on the Excel sheet are at A17 & H17. If more info is needed, just ask.
BL
BL
