Help with Excel formula, IF
raf
Im trying to create IF formula, from A1 to M1.
A1 to M1 could have a value of : "N/A", "PASSED"or any value
now what im trying to do is to have a formula that will show O1, If the user gets all passed fields, Or at lease one failed.
Formula logic should look like:
IF A1: M1 = PASSED or N/A then O1 = Passed
IF A1:M1= N/A or Any value then O1 = Failed
Passed if A1:M1 is just showing N/A or Passed, other than that is should show FAILED.
Thanks in advance!
Raf
I think this will do what you want
=IF((COUNTIFS(A1:M1,"PASSED")+COUNTIFS(A1:M1,"N/A"))>=12,"Passed","Failed")
Raf
Yeh your code worked, but, Im receiving Passed:with val value under K1, please see attached.
  • Book1.xlsx
In your original post you said there could be one failed ?
The formula
=IF((COUNTIFS(A1:M1,"PASSED")+COUNTIFS(A1:M1,"N/A"))>=12,"Passed","Failed") achieves that
If you need 13 values of Passed or N/A change the formula to
=IF((COUNTIFS(A1:M1,"PASSED")+COUNTIFS(A1:M1,"N/A"))=13,"Passed","Failed")
  • Like
Reactions: raf
The formula
looks Great! thank you so much Hui!
As Khalid said, there is no advantage
I had tried to incorporate the two conditions together in one Countifs() function, before realising that the logic was incorrect, hence the Countifs
The formula
Hi Hui,
What If I want to add this:
IF A1:M1="","",""
so it wont show Any value if the specific row is blank?
I think you need:
=IF(COUNTA(A1:M1)=13,IF((COUNTIFS(A1:M1,"PASSED")+COUNTIFS(A1:M1,"N/A"))>=12,"Passed","Failed"),"")
