Help with excel chart
james_kay
I have to amend a chart using VBA to plot column A(program) against column C(Date), at the moment it is mapped as column A(program) against column B(startsec).
the piece of VBA code that charts can be seen here
[pre]
Sub createprocesscharts()
Dim sets(2, 365) As Long
Dim limits(2, 365) As Long
Dim dates(365) As String
c = 1
r = 2
Sheets("Sheet1").Select
dt = Cells(r, 5)
sets(1, c) = r
limits(1, c) = Cells(r, 2)
While (Cells(r, 5) <> "")
If Cells(r, 5) <> dt Then
sets(2, c) = r - 1
limits(2, c) = Cells(r - 1, 2)
dates(c) = Format(Cells(r - 1, 5), "ddd, d mmm yyyy")
dt = Cells(r, 5)
c = c + 1
sets(1, c) = r
r = r + 1
Wend
sets(2, c) = r - 1
For i = 1 To c
Debug.Print sets(1, i) & " " & sets(2, i) & " " & limits(1, i) & " " & limits(2, i) & " " & dates(i)
Call makechart(sets(1, i), sets(2, i), dates(i), limits(1, i), limits(2, i))
Sub makechart(r1 As Long, r2 As Long, dt As String, l1 As Long, l2 As Long)
rstart = "$A$" & r1
rend = "$C$" & r2
rg = "'Sheet1'!" & rstart & ":" & rend
ActiveSheet.Shapes.AddChart.Select
With ActiveChart
.SetSourceData Source:=Range(rg)
.ChartType = xlBarStacked
.Legend.Delete
.Axes(xlValue).MinimumScale = l1
.Axes(xlValue).MaximumScale = l2
.SeriesCollection(1).Interior.ColorIndex = xlNone
.Axes(xlCategory).TickLabelSpacing = 1
.Axes(xlCategory).TickLabels.Font.Bold = True
.Axes(xlCategory).TickLabels.Font.Size = 8
.Location Where:=xlLocationAsNewSheet, Name:=dt
[/pre]
in essense , I want the `
` to take values from the E column and not C column.
I would be grateful for any help/suggestions for this issue.
I have uploaded the excel chart in here
https://www.dropbox.com/s/fo8ipmjpgem46go/create_chart.xls
Hi James ,
Can you check the file here ?
http://speedy.sh/zGRxp/create-chart-1.xls
I have made only one change , since I have not gone through the entire procedure ; what I find is that along with this change , if you hide column B of your data , the charts appear to be OK. Can you see this ?
Hi Narayan ,
thanks for the feedback. sorry I made a mistake in my post .
what i wanted to plot is column A(program) against column F(STARTTIME). I tried to hide columns like you did , but it isn't working for me.
James.
Hi Narayan,
is it possible to change the chart you uploaded to a Stacked Bar or column with an additional column "durationsec".could you change the code please ? ]
example chart of what I mean is here.
http://dl.dropbox.com/u/36755932/example%20chart.xls
thanks
james
