Help with a count? I think it should be easy!
Davealot
Greetings,
I'm sure this is an easy fix, I just have trouble with the loop in the function. Looking to write up code to check a range, B:B, for a specific set of text (MID,1,9)="76200-tk8", if it meets that criteria to pull information from adjacent column for quantity, and to loop through until it no longer matches the text, so that I can drop an open order report full of part numbers to sum up the totals in one cell.
Column B would be the part numbers, Column C would be the open amount, and I would have a separate sheet that would count the total amount of qty, matching criteria in a single cell.
I can obviously do a "CountIf" function, then sum that up in a separate column, but why do that when I know code can do it? I just can't get the loop down pat yet. Any help?
My bad, Forgot to attach. Needing it to search part numbers for criteria, find each part number and sum the total based on criteria. I was thinking I would need to use a sum if function, but the problem is that we have so many part numbers that are slightly varying in part number by models that I'm afraid a sumif won't function properly, thanks
If I add up all the Balances where the adjacent Part No's that start with "76200-tk8" I get a total of 1784 which are in 44 records
can you please explain the logic better
If you add a field to the Table "Left 9"
You could setup a Pivot Table
I'll admit I never even considered a pivot table, I was thinking something along the lines of writing code that would loop through each part number and if criteria was met, "76200-tk8" for example it would spit out the sum at the end. The pivot table will work well, but I get a new report every Monday, and I'm trying to develop something that will keep me as hands off as possible
Hi !
Use a filter and SUBTOTAL worksheet function for example …
Or better a COUNTIF as you well wrote …
What is your difficulty ?
