Help.. VBA code does not autorun
waseem
Dear VBA Gurus
Years ago I saw a post on this forum wherein if you click within a particular range of cells, the value in the selected cell is produced in a destination cell. For that I used following code:
>>> use code - tags <<<
Private Sub Macro1()
    If Not Application.Intersect(ActiveCell, [Input]) Is Nothing Then
        [Output] = ActiveCell.Value
"Input" is name of a range if cells and "Output" is a cell name where I am obtaining the output as text in the selected cell.
The above code is running well. However, it runs only when I run the macro manually. All I need is to ensure that as soon as I click on one of the input cells, the value in the selected cell should be reproduced in the output cell without manually running the code. Appreciate someone's help.
Cheers
waseem
Thank you Logit a lot for your prompt response. Actually I am not a VBA person so would appreciate if you could elaborate a bit about what is "MyMacro". It didnt work for me somehow.
Cheers
waseem
Just figured it out I wrote first line as
Private Sub Test ()
Now changed it to following and it worked.
Many thanks though for your support
