Help to change the lower case to upper case of character
sampath
my request is when enter the character in a cell, which will automatically change in uppercase. could you help me for this request.
Sampath.S
If it is for a specified range say A5:D10
you could use a small piece of VBA code as such
If Intersect(Target, Range("A5:D10")) Is Nothing Then Exit Sub
Target.Value = UCase(Target.Text)
Copy and place it in the Worksheet Module of the worksheet in VBA
Alternatively you could use some data validation to warn you that the cell isn't in Upper case
