Help required to populate data in specified format through VBA macro
HI ,
I have attached sample file , which has two sheets :
Sheet1 named Datasheet : This is a data sheet in which I have updated my data.
Sheet2 named OutputSheet: This is a output sheet in which I need to populate the data (as specified in my format) and using Filter (drop down) for identifying list of people are assigned or assigning in future in selected program.
NItesh
  • SampleSheet.xlsm
Datasheet D7: =IF(D$6<=DataSheet!$E2,DataSheet!$D2, IF(D$6<=DataSheet!$G2,DataSheet!$F2,IF(D$6<=DataSheet!$I2,DataSheet!$H2,IF(D$6<=DataSheet!$K2,DataSheet!$J2,"-"))))
Copy across and down
Then apply a Filter to the Output table
see attached file
  • SampleSheet.xlsm
Hi Nitesh
check the attachment
click on FillData button and see the result in NewOutput sheet
***did some changes in your data (changed date from 12/18/2018 to 12/1/2018) to make all dates uniform i.e. first day of the month
Thanks,
Hareesh
  • CopyProjectMonths.xlsm
