    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Help make recorded macro work (to obtain currency exchange rates)
Discussion in 'VBA Macros' started by Carlos Ruano, Mar 14, 2019.
  1. Carlos Ruano
    Carlos Ruano Member
    60
    Hi All,
    I am hoping that someone can help me make the code below work. I used the macro recorder to create it, but when I try to run it later, it fails at
    .CommandType = 0
    Run-time error '5': Invalid procedure call or argument
    Here is the recorded macro:
    Code (vb):
    Sub FXRate()
    ' FXRate Macro
       ActiveWorkbook.Worksheets.Add
        With ActiveSheet.QueryTables.Add(Connection:= _
            "FINDER;http://www.floatrates.com/daily/usd.xml", Destination:=Range("$A$1"))
            .CommandType = 0
            .Name = "usd"
            .FieldNames = True
            .RowNumbers = False
            .FillAdjacentFormulas = False
            .PreserveFormatting = True
            .RefreshOnFileOpen = True
            .BackgroundQuery = True
            .RefreshStyle = xlInsertDeleteCells
            .SavePassword = False
            .SaveData = True
            .AdjustColumnWidth = True
            .RefreshPeriod = 600
            .WebSelectionType = xlAllTables
            .WebFormatting = xlWebFormattingNone
            .WebPreFormattedTextToColumns = True
            .WebConsecutiveDelimitersAsOne = True
            .WebSingleBlockTextImport = False
            .WebDisableDateRecognition = False
            .WebDisableRedirections = False
            .Refresh BackgroundQuery:=False
        Sheets("Sheet2").Select
        Sheets("Sheet2").Name = "FX Rates"
    I used instructions on the following site when recording the above macro:
    https://office-watch.com/2016/excel-easily-get-the-latest-currency-exchange-rates/
    If you have a different solution that would allow me to obtain currency exchange rates, that would also be fine. I would really like it to be run in a macro if possible.
    I did find the following function:
    Code (vb):
    Public Function wConvertCurrency(currency1, currency2)
    Dim yahooHTTP As New WinHttp.WinHttpRequest
    yahooHTTP.Open "GET", "http://download.finance.yahoo.com/d/quotes.csv?s=" & currency1 & currency2 & "=X&f=l1"
    yahooHTTP.send
    wConvertCurrency = CDbl(yahooHTTP.ResponseText)
    End Function
    BUT ... I don't know how to make it work. Should I put it in a module like a sub procedure? I tried that, and it didn't work.
    Any help would be greatly appreciated!
    Carlos
  2. Marc L
    Marc L Excel Ninja
    4,274
    Hi !
    As a beginner starter from my recorder :​
    Code (vb):
    Sub Macro1()
            "URL;http://www.floatrates.com/daily/usd.xml", Destination:=Range("A1"))
            .PreserveFormatting = False
            .RefreshStyle = xlOverwriteCells
            .SaveData = True
            .AdjustColumnWidth = False
            .Delete
    Carlos Ruano likes this.
  3. Carlos Ruano
    Carlos Ruano Member
    60
    Awesome! Thank you, Marc!
  4. AlanSidman
    AlanSidman Active Member
    459
    Here is a Currency Exchange Template that I use. It employs Power Query. To update it daily, click on the Data-->Refresh Button twice. Sometimes Three Times.
Share This Page
