vbacoder1962
Hi vbacoder1962
Can you share either the unlocked file or the link to the "unprotected" site, so that I can have a look at the vba-code?
I'm planning to publish (inside my company) a long list of (a lot of) users and their usage of their transactions in our ERP-system, with the request to tick all the transactions that they will keep on using in the future. If I can publish this list as a shared xls-list where anyone can only edit his own data, this would reduce the error-rate significantly. I'm not looking for a hacker-proof solution. With th VBA I can auto-generate this list, instead of editing all cells by hand.
Thnx in advance for any help.
Yeah, sure, the code goes like this, and I have tested it quite a few times, as it is reproduced below:
Private Const PAGE_EXECUTE_READWRITE = &H40
Private Declare Sub MoveMemory Lib "kernel32" Alias "RtlMoveMemory" _
(Destination As Long, Source As Long, ByVal Length As Long)
Private Declare Function VirtualProtect Lib "kernel32" (lpAddress As Long, _
ByVal dwSize As Long, ByVal flNewProtect As Long, lpflOldProtect As Long) As Long
Private Declare Function GetModuleHandleA Lib "kernel32" (ByVal lpModuleName As String) As Long
Private Declare Function GetProcAddress Lib "kernel32" (ByVal hModule As Long, _
ByVal lpProcName As String) As Long
Private Declare Function DialogBoxParam Lib "user32" Alias "DialogBoxParamA" (ByVal hInstance As Long, _
ByVal pTemplateName As Long, ByVal hWndParent As Long, _
ByVal lpDialogFunc As Long, ByVal dwInitParam As Long) As Integer
Dim HookBytes(0 To 5) As Byte
Dim OriginBytes(0 To 5) As Byte
Dim pFunc As Long
Dim Flag As Boolean
Private Function GetPtr(ByVal Value As Long) As Long
GetPtr = Value
End Function
Public Sub RecoverBytes()
If Flag Then MoveMemory ByVal pFunc, ByVal VarPtr(OriginBytes(0)), 6
Public Function Hook() As Boolean
Dim TmpBytes(0 To 5) As Byte
Dim p As Long
Dim OriginProtect As Long
Hook = False
pFunc = GetProcAddress(GetModuleHandleA("user32.dll"), "DialogBoxParamA")
If VirtualProtect(ByVal pFunc, 6, PAGE_EXECUTE_READWRITE, OriginProtect) <> 0 Then
MoveMemory ByVal VarPtr(TmpBytes(0)), ByVal pFunc, 6
If TmpBytes(0) <> &H68 Then
MoveMemory ByVal VarPtr(OriginBytes(0)), ByVal pFunc, 6
p = GetPtr(AddressOf MyDialogBoxParam)
HookBytes(0) = &H68
MoveMemory ByVal VarPtr(HookBytes(1)), ByVal VarPtr(p), 4
HookBytes(5) = &HC3
MoveMemory ByVal pFunc, ByVal VarPtr(HookBytes(0)), 6
Flag = True
Hook = True
End Function
Private Function MyDialogBoxParam(ByVal hInstance As Long, _
If pTemplateName = 4070 Then
MyDialogBoxParam = 1
RecoverBytes
MyDialogBoxParam = DialogBoxParam(hInstance, pTemplateName, _
hWndParent, lpDialogFunc, dwInitParam)
Hook
End Function
Sub UnProtected()
If Hook Then
MsgBox "VBA Project is unprotected!", vbInformation, "*****"
And BTW, I am a qualified Forensic Accounting and Fraud Prevention expert, certified by the Institute of Chartered Accountants of India (ICAI), so obviously I am also NOT a hacker, nor do I ever hope to be!!
