    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Function Variable Not Updating
Discussion in 'VBA Macros' started by Davis Henderson, May 11, 2018.
  1. Davis Henderson
    Davis Henderson New Member
    27
    Hi All. I have several macros that I am trying to run at the same time. Each one has the same function as seen below that updates the page number where the value is found. Some of the macros grab the correct page number, but some don't. I am printing where the value is found, and they are always correct. For example, if the file is found on C2 on the 9th page, often the return value is C2.1 instead of the correct C2.9. I know that is a lot of information, but if there is anything in my code that could explain the pageNum Variable not consistently updating correctly, it would be greatly appreciated!
    Code (vb):
    Sub Find_DatDenverExp()
    'Denver Exp Macro
        Dim datatoFind As String, MySheet As String, FV As String
        Dim aSh As Worksheet, fSh As Worksheet
        Dim firstResult As Range
        Dim secondResult As Range
        Dim rng As Range
        Dim LeftCell As Range
        Dim leftValue As String
        Dim RowCount As Integer
        Dim rw As Long
        Dim counter As Integer
        Dim sheetNumber As Integer
        Dim sheetCount As Integer
        Dim findValue As Range
        sheetNumber = ActiveWorkbook.Sheets.Count
        For counter = 1 To sheetNumber
            Sheets(counter).Activate
            'Denver Exp Macro
       Set rng = Cells.Find(What:="Denver Exp", after:=Sheet1.Cells(1, 1), LookIn:=xlFormulas, LookAt:=xlWhole, SearchOrder:=xlByRows, SearchDirection:=xlNext, MatchCase:=True, SearchFormat:=False)
        If Not rng Is Nothing Then
        Exit For
        Next counter
        Set LeftCell = rng.Offset(0, -1)
        leftValue = LeftCell.Value
        'Ref. with one space after Ref.
       If leftValue = "Ref. " Then
        For rw = 1 To 10000
        Set findValue = rng.Offset(rw, 0)
        datatoFind = findValue
        sheetCount = ActiveWorkbook.Sheets.Count
        'Skipping the row that has a Zero
       If Len(datatoFind) = 1 Then GoTo lastLine
        'Stopping the macro where the values arer bold or grey
       If Len(datatoFind) = 0 Or Not IsNumeric(datatoFind) Or findValue.Font.Bold Then Exit Sub
        For counter = 1 To sheetCount
        Set firstResult = Cells.Find(What:=datatoFind, LookIn:=xlFormulas, LookAt:=xlWhole, SearchOrder:=xlByRows, SearchDirection:=xlNext)
        If Not firstResult Is Nothing Then
        Set secondResult = Cells.FindNext(firstResult)
        Debug.Print secondResult.Address
        With secondResult
            MySheet = IIf(InStr(secondResult.Parent.Name, "."), Split(secondResult.Parent.Name, ".")(0), Split(secondResult.Parent.Name)(0))
            FV = MySheet & "." & pageNum8(secondResult)
        Next counter
        With rng.Offset(rw, -1)
            .Value = FV
            .Font.Name = "Times New Roman"
            .Font.Bold = True
            .Font.Size = "10"
            .Font.Color = vbRed
            .HorizontalAlignment = xlRight
            .VerticalAlignment = xlCenter
    lastLine:
        Next rw
    Function pageNum8(rng As Range)
        Dim vA, hA
        Dim iRow As Long, iCol As Long, I As Long
        Dim pg8 As String
        With rng.Parent
            If .HPageBreaks.Count > 0 Then
                ReDim hA(0 To .HPageBreaks.Count)
                hA(0) = 1
                For I = 1 To UBound(hA)
                    hA(I) = .HPageBreaks(I).Location.Row
                ReDim hA(0 To 0)
                hA(0) = 0
            If .VPageBreaks.Count > 0 Then
                ReDim vA(0 To .VPageBreaks.Count)
                vA(0) = 1
                For I = 1 To UBound(vA)
                    vA(I) = .VPageBreaks(I).Location.Column
                ReDim vA(0 To 0)
                vA(0) = 0
            iRow = Application.Match(rng.Row, hA, 1)
            iCol = Application.Match(rng.Column, vA, 1)
            If .PageSetup.Order = xlDownThenOver Then
                pg8 = (iCol - 1) * (.HPageBreaks.Count + 1) + iRow
                pg8 = (iRow - 1) * (.VPageBreaks.Count + 1) + iCol
        pageNum8 = pg8
    End Function
  2. Davis Henderson
    27
    Bump if anyone could help out on this issue.
  3. p45cal
    p45cal Well-Known Member
    1,247
    It is far too difficult to keep in one's head the various contents of the variables in your code. Attach a file, and tell us which result(s) is (are) wrong in that file when the code has been run.
  4. Luke M
    Luke M Excel Ninja
    9,383
Share This Page
