Formulae with a double if
Hi
Please refer to tab: Testing_Main - cell AR10
I can't get it work.
I need if AP10 and AQ10 are both 1 - then "Testing Completed"
I need if AQ1 is 1 and AP is 0 - then" Please Update the Empty Cells"
It sound so simple, and I tried all with online excel bot - did not work in my excel.
Can you please open my excel and see if you can get it work in the actual excel. . Currently I see 'false"
Thanks -
David.
  • SOX_Testing_Template_Generic__Final_V5.0.xlsm
=IF(AND(AP10=1,AQ10=1),"testing Complete", IF(AND(AP10=0,AQ10=1),"please update the empty cells",""))
but your formula in Ap10 is adding text not numbers
"1" is text and not seen as a 1
so change to
=IF(COUNTBLANK(B10:p10)>0,0,1)
what if AQ is 0 ???
I have left blank
  • SOX_Testing_Template_Generic__Final_V5.0 - ETAF.xlsm
so change to
what if AQ is 0 ???
I have left blank
Thanks, all day and I never saw the mistake of the "" changing to text..... great spot :)
what if AQ is 0 ??? this would be when cell q10 was not completed - for example.
Thank you so so so so so much!!!!!!!!!!!!!!!!!!!!!!!!
Hi
Are you able to put those cool excel skill to help me on tab: Testing_Main - cell B10
I want the cell to turn red if the cell is empty and cell P10 is empty.
One you fix this I will need to do this all on cells from B10 to p10 - unles you have a quick fix for that.
thanks
David.
  • SOX_Testing_Template_Generic__Final_V6.0.xlsm
yea, sure , but as its a new question, then a new thread should be made , i can then answer the new thread
