I would like to dynamically group the sample events of the same date and then applying that grouping for calculating daily MIN MAX values. Uploading a small sample data set as an example of the data format. The data spreads over 10 years in thousands of entries so cannot do the grouping manually.
Events are not sampled on consecutive dates.
Number of daily sample events can vary.
Data is in columns labelled: Date | Time | Sample Value 1 | Sample Value 2 |... ...|Sample Value n |
Date format is yyyy:mm:dd
Time format is 00:00:00 (24 hrs)
Sample event format: 1.123456
I have minimal vba knowedge so would prefer formula if possible.
I have asked this question at Stack Overflow with no response. Would appreciate your assistance.
Thank you
Thank you
