for each cell in range - work by row or by column
GeorgeF211
Hi all,
in VBA, the statement
For Each Cell In Range
is used quite a bit.  My question is, does this function cycle through by row or by column, i.e. for the range A1:B3 would it work through in the order
[code]a1, a2, a3, b1, b2, b3
or
a1, b1, a2, b2, a3, b3[/code]
I'm sure this is something that is pretty common knowledge, but I can't seem to find an answer on the internet (search criteria for this kind of thing are hard, so it could be I'm not trawling correctly).
Thanks,
George
Hi George ,
Try this and see :
[pre]
Public Sub ForEach()
For Each cell In Selection
MsgBox cell.Address
[/pre]
Select your range before you run this macro.
Cheers Narayank, it's always best to have someone show you how to find something out rather than hold your hand.
Useful thing to know as a function too.
You should Dim the Cell variable
The code should be:
[pre]
Dim cell As Range
MsgBox cell.Address
[/pre]
