First empty cell Column
S P P
Last empty cell column(2)
ActiveSheet.ListObjects(1).Range.Columns(2).Find("", SearchOrder:=xlByRows, SearchDirection:=xlPrevious).Activate
How would it be
First empty cell Column(2)
rollis13
Maybe just:
ActiveSheet.ListObjects(1).Range.Columns(2).Find("", SearchOrder:=xlByRows, SearchDirection:=xlNext).Activate
rollis13
The only way I know with a Table without Headers is to leave the Headers visible and use the white color for the interior and font on those cells to 'hide' them. This will let you use the above code and if the column is empty it will activate the first cell instead of the second.
S P P
rollis13
I'm going to use it anyway, just don't select the first cell, but in the second it already works.
