Filtering of data and separate into two worksheets.
VDS
Dear Experts,
I am attaching herewith two excel files. Testing File & Dummy
Testing File contains thee worksheets namely "Data", "Active" and "Closed" in which I have separated the data of "Active" and "Closed" by using array formula /command
I have to use the same formula in the Dummy file where there are larger number of columns. in the dummy file it is "Disposed" and "Active". When I try to copy paste the command, it gives result 0.
Please help me in getting the correct output. In fact this solution has given by some of the experts from Chandoo.org very long back. But cant remember how to apply.
VDS
vletm
VDS
About Your In fact this solution has given by some of the experts from Chandoo.org very long back. But cant remember how to apply.
You could try to do next steps:
#1 Move Your mouse cursor over VDS -text below Your picture
#2 Move Your mouse cursor over 384
#3 Push Your mouse's right button down to get menu
#4 Select Open Link in New Tab to see Your previous messages
