Filter and copy data from one column to two
JBrauny
I currently have a line header and associated numbers exported into excel in the same column.
The following example is currently in one column. I need to separate and expand these into two columns.
Example:
LINE ABC
3030C
10026A
10026B
10026C
LINE ABH
7595
7644
11146
16837
16838
8150009C
8150064C
Needs to look like following in two columns:
ABC 3030C
ABC 10026A
ABC 10026B
ABC 10026C
ABH 7595
ABH 7644
ABH 11146
ABH 16837
ABH 16838
ABH 8150009C
ABH 8150064C
Thoughts?
jay
Hi Jay ,
A VBA procedure will be simple compared to a formula solution. Is this OK with you ?
Secondly , you have shown the word LINE as the header ; will this word actually appear or have you shown it just to give us the idea ? In the procedure , can this word be used to determine a header , so that entries after this will all appear in a second column , till we come across another LINE ?
Narayan-
Whatever is simple is OK with me. I will learn VBA sometime; better with guidance than on my own.
Yes - the data shown is as it is exported; LINE appears as I have it and the following digits (ABC or ABH in this case) will always be 3. There is a possibility of LINE LIN to which I have some numbers associated with, but just a handful.
Currently the data comes formatted as text but I multiply the column by 1 to get it to a number. I am open to how I clean the data right now because I am on the front end of this project.
jay
Try this and see if it works :
[pre]
Public Sub Temp()
Const HEADER_TEXT = "LINE"
Set s2 = ThisWorkbook.Sheets("Sheet2")
s2.Activate
Range("A1").Select
Set s1 = ThisWorkbook.Sheets("Sheet1")
s1.Activate
Range("A5:A17").Select
offset_count = 0
For Each text_item In Selection
left_part = Left(text_item, 4)
If left_part = HEADER_TEXT Then
s2.Activate
current_header = Right(text_item, 3)
ActiveCell.Offset(offset_count, 0).Value = current_header
s2.Activate
ActiveCell.Offset(offset_count, 1).Value = text_item
offset_count = offset_count + 1
s1.Activate
[/pre]
Hi JBrauny,
This won't give exactly what you want, but it will split it into 2 columns as desired
Paste your data starting in A2
Put this into B2
=IF(LEFT(A2,4)="LINE",TRIM(RIGHT(A2,LEN(A2)-4)),B1)
And this into C2
=IF(LEFT(A2,4)="LINE","",A2)
which will give this
ABC
ABC 3030C
ABC 10026A
ABC 10026B
ABC 10026C
ABH
ABH 7595
ABH 7644
ABH 11146
ABH 16837
ABH 16838
ABH 8150009C
ABH 8150064C
The rows with LINE will have a blank. You could combine this with a little VBA that:
- inserts the formulas
- copy paste/special values
- filters down on the blanks
- deletes those visible rows
- unfilters
Hi Jay ,
Sorry to know that you had problems ; I can only imagine that certain changes which needed to be made at your end were not made. The following section of code needs to be changed to suit the names and data ranges in your worksheet ; did you make these changes ?
s2.Activate
Range("A1").Select
s1.Activate
Sheet1 , Sheet2 are tabs which need to be changed depending on the tabs in which you have data in your workbook.
The range A5:A17 is the one where I copied and pasted the sample data you had posted ; you need to change this line to reflect your actual data range.
A1 is the starting cell from where the data will be put the way you want it to be formatted ; change this if required.
The entire code has to be copied into the ThisWorkBook section in VBA Explorer.
Narayan - Thank you for the follow up explanation. I changed the range and it worked like a charm.
I would like to expand on what I just learned. With the orig data in column A, how could I have subsequent data in additional columns follow our expansion that the macro performs?
I'm assuming having the macro move the data is the most efficient way. If there is easier, please recommend.
Example:
Column A ColumnB ColumnC
LINE ABC
3030C 5 4.9
10026A 4 5.4
10026B 2 4.8
10026C 7 7.8
LINE ABH
7595 2 5.5
7644 2 1.1
11146 3 4.1
16837 2 4.6
16838 3 3.2
8150009C 1 2.2
8150064C 2 2.1
to
ABC 3030C 5 4.9
ABC 10026A 4 5.4
ABC 10026B 2 4.8
ABC 10026C 7 7.8
ABH 7595 2 5.5
ABH 7644 2 1.1
ABH 11146 3 4.1
ABH 16837 2 4.6
ABH 16838 3 3.2
ABH 8150009C 1 2.2
ABH 8150064C 2 2.1
I am new to VBA, please be patient with my questions. It's like learning excel functions all over again and I'm sure answers are right in front of me.
jay
Kyle - Thanks for the viewpoint. I follow your thoughts and it worked well in a test worksheet. My actual sheets are up to 30K + rows which I am trying to automate.
As I learn VBA more, I may just try to record a macro that uses it. Regardless, I've never used TRIM, etc.
Thanks to you and Narayan for teaching me.!
Jay
Narayan - I just noticed that I had Column A, B, and C spaced out as I typed my reply above, but it was condensed down when it posted.
jay
Hi Jay ,
Nice to know you are on the VBA road ; may your journey take you to interesting places !
If you need to expand your data columns , the modified code is shown below :
[pre]
Public Sub Temp()
Const SPACE = " "
s2.Activate
Range("A1").Select
s1.Activate
offset_count = 0
s2.Activate
s2.Activate
'..........Process the several items in the same cell............
current_string = text_item
len_string = Len(current_string)
current_item = ""
item_count = 1
char_count = 1
Do
current_char = Mid(current_string, char_count, 1)
If (current_char <> SPACE) Then
current_item = current_item + current_char
If ((current_char = SPACE) Or (char_count = len_string)) Then
ActiveCell.Offset(offset_count, item_count).Value = current_item
current_item = ""
item_count = item_count + 1
char_count = char_count + 1
Loop Until char_count > len_string
'..........End of Processing several items in the same cell............
s1.Activate
[/pre]
Narayan - Thank you!!
As I read the code, I'm seeing "items in the same cell."
So is this assumption that "3030C 5 4.9" is all in one cell.? My intent was to show that 3030C, 5, & 4.9 are in individual columns.
jay
Hi Jay ,
Sorry , my mistake. Then the changes to the first code are far simpler. I'll post them after some time.
Hi Jay ,
The revised code is as under ; I am sure you can see the changes which have been made , and add to them if you need more columns to be formatted.
[pre]
Public Sub Temp()
s2.Activate
Range("A1").Select
s1.Activate
offset_count = 0
s2.Activate
ActiveCell.Offset(offset_count, 2).Value = s1.Range(text_item.Address).Offset(0, 1).Value
ActiveCell.Offset(offset_count, 3).Value = s1.Range(text_item.Address).Offset(0, 2).Value
s1.Activate
[/pre]
Narayan -
Yes I see the differences. I will let all this sink in today and play with it this weekend.
Thanks for the help.
jay
