Extracting Unique values, Sorting And summing
Hii
Below are the two screenshots one is Input and other is output
Input Screen
Output Screen
Can you please tell me how to extract unique value from column D and sort it and then sumif column B And Column C
If this doesn't work, attach your workbook.
Sub test()
    Dim a, i As Long, w, x As Object
    a = Cells(1).CurrentRegion.Value
    With CreateObject("System.Collections.SortedList")
        For i = 2 To UBound(a, 1)
            If Not .Contains(a(i, 4)) Then
                .Item(a(i, 4)) = Array(a(i, 4), a(i, 2), a(i, 3))
                w = .Item(a(i, 4))
                w(1) = w(1) + a(i, 2): w(2) = w(2) + a(i, 3)
                .Item(a(i, 4)) = w
        Set x = .Clone
    With Sheets.Add.Cells(1).Resize(, 3)
        .Value = Application.Index(a, 1, [{4,2,3}])
        For i = 0 To x.Count - 1
            .Rows(i + 2).Value = x.GetByIndex(i)
Is very genial,
but I dont know,,.. whats about the items, this is confuse for me
Of course, that's how you want the result
Hi !
Other way for beginners : use Excel BASICS !
Like advanced filter, sort and easy COUNTIF worksheet function …
