I have an Excel file with data in a tab, which through the macro below I was able to create a Word file from scratch, copy the content of the Excel tab and paste it into Word, but the header and footer don't come to Word and I'm managing to include them.
>>> use code - tags <<<
Could you help me editing the macro above by inserting a code so that in Word I have the following result:
- in the footer of each page, on the left end it receives text from cell A1 in Excel, in the center also text from cell A2 in Excel, and on the right end of the footer it receives "Page X of Y" where X and Y are the current page and total peage number of the open word file. (I understand that Word does not separate the footer into 3 parts like Excel does, so the solution here may be a combo code that transfers the 3 sections at once as if it were a single sentence in the Word footer, using concatenation of variables with fixed texts and some spaces or tabs to simulate a footer divided into 3 parts with these 3 inputs?)
- in the header on all Word pages, just receive a logo (.bpm) at the right end (This .bmp file is already inserted as a figure next to cell A4 in Excel). It is also inserted in the excel header as an image so maybe it could be copied from there in excel and pasted in the Word doc header?
Would it be possible?
>>> use code - tags <<<
Sub ExcelToWord()
Dim ws As Worksheet
Set ws = ActiveSheet
Dim objWd As Object
Set objWd = CreateObject("word.application")
Dim myPath As String
Dim folderPath As String
Dim fso As Object
Set fso = CreateObject("Scripting.FileSystemObject")
myPath = fso.GetBaseName(ActiveWorkbook.Name)
folderPath = Application.ActiveWorkbook.Path
objWd.Visible = True
Dim objDoc As Object
Set objDoc = objWd.Documents.Add
objDoc.PageSetup.Orientation = 0 ' portrait = 0
ws.UsedRange.Copy
objDoc.Content.Paste
