Excel Chart Obect position - Using VBA
nagovind
Dear All
I have a x-y scatter chart to plot the values
i will switch it ON and OFF the values using VBA; during the same time i need to show an
ARROW head simultaneouly get switched ON/ OFF OVER THE CHART Area..the same arrow head nothing but as object can be deleted ...but while switching ON the x-y scatter new arrow head should be shown in the same place (co-ordinate)
Is it possible using excel VBA
Please help
Nagovind
You have 2 basic options
With VBA
Add an arrow to your chart and thenwith VBA
With ActiveSheet.Shapes.Range(Array("Rectangle 1")) 'Change name of object to suit
.Visible = msoTrue 'Shows object
.Visible = msoFalse 'Hides object
Without VBA
Add another series to the chart which will only have one set of coordinates
Change coordinates to suit desired location
Add an arrow to your workbook
Select an Arrow, Copy
Now select your new single point Series and paste
Your points coordinates can have a formula to make them appear where ever you like on the page
