Aman Semwal
Here is my code :
>>> use CODE -tags <<<
Please help me as do while stop after first iteration.
>>> use CODE -tags <<<
Worksheets(2).Activate
Range("K2").Value = q
Range("P2").Value = q
Range("S2").Value = p
Dim xws1 As Workbook
Dim wbk10 As Workbook
Dim filename1 As String
Dim path10 As String
Set xws1 = Application.ActiveWorkbook
path10 = "I:\PROJECTS\mds\INPUT FILES\"
filename1 = Dir(path10 & "")
'wbk10 is the extract TMC file
'It opens one by one and will give output
Do While filename1 <> ""
Set wbk10 = Workbooks.Open(path10 & filename1)
'xws1 file gets activate and value are automatically gets paste on the file
wbk10.Activate
Columns("A:A").Select
ActiveSheet.Range("$A$1:$AP$60000").RemoveDuplicates Columns:=1, Header:=xlNo
Range("A2:A20").Select
Selection.Copy
xws1.Activate
Sheets("Sheet2").Select
Range("A2").Select
ActiveSheet.Paste
wbk10.Activate
Range("C2").Select
Selection.Copy
xws1.Activate
Sheets(2).Select
Range("M2").Select
:=False, Transpose:=False
Cells(2, 13).Value = Trim(Cells(2, 13))
wbk10.Activate
wbk10.Close savechanges:=False
xws1.Activate
Dim wbk101 As Workbook
Dim X As Range
Set wbk101 = Workbooks.Open("I:\Corp\BTA\PROJECTS\Statement\Kzoo Report\BTA\BTA.xlsx")
Set X = wbk101.Worksheets("Sheet1").Range("E:AA")
Dim j As Integer
With xws1.Sheets(3)
For j = 2 To 20
.Cells(j, 2) = Application.VLookup(.Cells(j, 1).Value2, X, 23, False)
Next j
wbk101.Close savechanges:=False
xws1.Activate
xws1.Sheets(3).Select
Columns("B:B").Select
Selection.Replace What:="#N/A", Replacement:="", LookAt:=xlPart, _
SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _
ReplaceFormat:=False
Columns("b:b").Select
ActiveSheet.Range("$b$1:$b$60000").RemoveDuplicates Columns:=1, Header:=xlNo
Cells(2, 3) = Cells(2, 2) & ";" & Cells(3, 2) & ";" & Cells(4, 2) & ";" & Cells(5, 2) & ";" & Cells(6, 2) & ";" & Cells(7, 2) & ";" & Cells(8, 2) & ";" & Cells(9, 2) & ";" & Cells(10, 2) & ";" & Cells(11, 2) & ";" & Cells(12, 2) & ";" & Cells(13, 2)
Cells(2, 3).Copy
Sheets(2).Select
Range("D2").Select
Dim oMSOutlook As Object
Dim oEmail As Object
Dim k As Integer
Dim strBody As String
'Dim Pth As String
'Pth = "I:\PROJECTS\mds\OUTPUT FILES\"
Set oMSOutlook = CreateObject("Outlook.Application")
k = 2
Set oEmail = oMSOutlook.CreateItem(olMailItem)
With oEmail
.SentOnBehalfOfName = "semwal.aman21@gmail.com"
.To = Cells(k, 4)
.Cc = Cells(k, 2)
.Subject = Cells(k, 5)
.Body = Cells(k, 3)
'.Attachments.Add Pth & Dir(Pth & Cells(2, 5) & ".xlsb")
.Save
Set oMSOutlook = Nothing
Set oEmail = Nothing
Sheets(3).Activate
Range("A1:E100").Delete
filename1 = Dir
Loop
