It does when you use Ctrl+C
that copies everything
Then goto the destination cell and paste what you want
Right click on the destination cell, seelctPaset Special
Then look at each of the available options
If you want to remove the Formatting from the source cell, use Cut (Ctrl+X) instead of Copy
sir.may i am unable to explain my problem because English is not a language of us..i try to explain again to you..
there is no color in cell and also no any conditional formatting..i want when i press (ctrl+c) cell change its color its self for my remembering.
