Countif with 2 conditions help
CharlesW
I'm trying to write a formula with 2 conditions
A B
1 $161.00 60
2 $20.00 80
3 -$20.00 90
4 -$100.00 30
What I want to determine is :
Number of A that are >0 and > than .5 of B in the same row
Number of A that are >0 and < than .5 of B in the same row
Number of A that are <0 and > than .5 of B in the same row
Number of A that are <0 and < than .5 of B in the same row
and count each category.
I was trying to use this formula
=COUNTIF(A1:A1,">=0")-COUNTIF(A1:A1,">B1*.5")
but it's not taking in to account the second formula(syntax problem?) and additionally that only counts the 1 row and not all of the rows.
Any help would be greatly appreciated.
Should be something like this. Note that your stated conditions were exclusive of the boundary condition, so I changed all of the ">" to become ">=". Change back if desired.
=SUMPRODUCT((A2:A100>=0)*(A2:A100>=0.5*B2:B100))
=SUMPRODUCT((A2:A100>=0)*(A2:A100<0.5*B2:B100))
=SUMPRODUCT((A2:A100<0)*(A2:A100>=0.5*B2:B100))
=SUMPRODUCT((A2:A100<0)*(A2:A100<0.5*B2:B100))
Oops, there is a problem. I'm only trying to count column A by rows. I'm not familiar with sumproduct but heres an example from my spread sheet.
A B
1 50 20
2 -150 30
=SUMPRODUCT((A2:A100>=0)*(A2:A100>=0.5*B2:B100)) returns 3 should be 1 (from row 1)
=SUMPRODUCT((A2:A100>=0)*(A2:A100<0.5*B2:B100)) returns 0 should be 0
=SUMPRODUCT((A2:A100<0)*(A2:A100>=0.5*B2:B100)) returns 0 should be 0
=SUMPRODUCT((A2:A100<0)*(A2:A100<0.5*B2:B100)) returns 1 should be 1 (from row 2)
This seems to be counting both conditions separately because the total returns 4 instead of 2. I'm not sure if I explained just counting the rows and not each value correctly.
Thanks.
Charles
I assume your data listed above as:
A B
1 50 20
2 -150 30
should be
A B
2 50 20
3 -150 30
Then the first formula
should be
=SUMPRODUCT((A2:A100>0)*(A2:A100>=0.5*B2:B100))
