Jack-P-Winner
When you run this Macro it will start counting down. It counts the amount of each individual number like the 5's in column E row 4 and puts a 4 in column L. It does the same thing all the way down. Another example is it counts the 2's in row 11 column d and puts the nswer (12) in column L. What I need to happen is when it comes to the 1's and 9's I need for it to count them as a whole entity and also as a separate number. Example rows 15 and 16. I need to coumd all the 9's and 1's as a whole and then break them down individual You will see it says a total of 4 in row 15 column Y and the a 2 in column Z. The same with row 16 If we look at row 50 it has a total count of 12 and it places a 6 in Y for the 1's and in row 56 it places a 6 for the 9's. Make sense? Now, I do not want the 9's and 1's in columns X and Y as this was only an example but I would like them in column L and M. Put the total count in L and the individual count in M.
Again, Thank you Guru's
