Count no of Poles as per setting
Juniad
Hi, i have one sheet where i want to count the no of poles.. i want to fix the camera's on pole so no of camera's i will set in setting cell so based on setting cell i want to count the no of poles.
Exp:
in setting cell if i set 2 cameras per pole then whatever i enter in camera cell pole should be calculated automatically.
Attachment is available for further detail.
  • Example.xlsx
Maybe change ROUND to ROUNDUP:
=IFERROR(ROUNDUP(IF(F4=2,G4/2,G4/F4+IF(MOD(G4,F4)>1,0,MOD(G4,F4))),0),"")
Hi Junaid,
If you can include your all inputs with expected results, it will be easy to share targeted answers.
You can also use Ceiling function:
=CEILING(G4/F4,1)
Rounding up, the number of cameras you must be able to mount is
= CEILING(cameras, setting)
This requires
= CEILING(cameras, setting) / setting
poles. If you also wish to avoid showing errors when 'setting' is not input
= IF( setting, CEILING(cameras, setting) / setting, "" )
