    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Count between Two Cells
Discussion in 'Ask an Excel Question' started by fareedexcel, Oct 11, 2017.
  1. fareedexcel
    fareedexcel New Member
    24
    Dear Experts,
    I require to check the count interval between the 1st OFF to the Last OFF. After the Last OFF, count should not happen. Expected result attached for your reference.
  2. vletm
    vletm Well-Known Member
    3,275
    fareedexcel
    Just modify those '-' and 'OFF' as You need...
  3. p45cal
    p45cal Well-Known Member
    1,001
    See attached with UDF:
    Code (vb):
    Function myCounts(rng) As String
    ResultStr = ""
    rngVals = rng.Value
    For c = 2 To UBound(rngVals, 2)
      Select Case True
        Case UCase(Application.Trim(rngVals(1, c - 1))) = "OFF" And UCase(Application.Trim(rngVals(1, c))) <> "OFF": Start = c
        Case UCase(Application.Trim(rngVals(1, c - 1))) <> "OFF" And UCase(Application.Trim(rngVals(1, c))) = "OFF"
          If Start > 0 Then If Len(ResultStr) = 0 Then ResultStr = c - Start Else ResultStr = ResultStr & "-" & c - Start
      End Select
    Next c
    myCounts = ResultStr
    End Function
    Thomas Kuriakose likes this.
  4. fareedexcel
    24
    Thank you for your help and support.
  5. fareedexcel
    24
    The Code is working fine. Is there any way to understand the logic. I would like to learn more on automating stuffs in excel.
  6. p45cal
    1,001
    I'm sorry, but no; explaining the logic in full takes 10 to 20 or even 30 times as long as writing the code.
  7. fareedexcel
    24
    Thanks for your support Expert. I need one more modification from the same file, for eg: in the pattern if any of them has more than value 7 (6-8-6, 12-6-8,6-6-6-8) then those rows should come in another sheet. Is it possible with Macros instead of doing with formula.
  8. vletm
    3,275
    fareedexcel
    Yes ...
    Do You have any name of that other sheet and to which row?
    Do You have sample output?
  9. p45cal
    1,001
    Button at cell AP1 of Check sheet in attached, which calls the code below.
    Uses the same user defined function as before.
    Code (vb):
    Sub blah()
    Limit = 7
    For Each rw In Sheets("Check").Range("I4:AM19").Rows
      x = myCounts(rw)
      If Len(x) > 0 Then
        y = Split(x, "-")
        GreaterThanLimit = False
        For Each Z In y
          If CLng(Z) > Limit Then
            GreaterThanLimit = True
            Exit For
        Next Z
        If GreaterThanLimit Then Set Destn = Sheets("Sheet1").Cells(Rows.Count, "A").End(xlUp).Offset(1) Else Set Destn = rw.Cells(1).Offset(, 33)
        With Destn
          .NumberFormat = "@"
          .Value = x
    Next rw
  10. fareedexcel
    24
    After the pattern is captured in the 1st sheet. Above 7 should get captured in the second sheet. Please help on the same. Expected result attached. Thanks for the help Experts.
  11. fareedexcel
    24
    Output I have mentioned right now
  12. vletm
    3,275
    fareedexcel
    Output as You have mentioned right now...
    fareedexcel and Thomas Kuriakose like this.
  13. p45cal
    1,001
    See attached.
  14. fareedexcel
    24
    This is Brilliant. Thanks for the Support
  15. fareedexcel
    24
    Thanks Expert :)
Share This Page
