I need a macro that will copy A11770 if text is found in Column A
I need it to find the Sheet that users are working on see Macro Example and copy to another worksheet that will always be called Costings
This is what I tried to start with but way to confusing and long.
Sub MoveEstimate_to_Costings()
Dim SHEETNAME As String
SHEETNAME = "Estimate1"
SHEETNAME = InputBox("enter the name of a sheet to use", "sheet name", SHEETNAME)
Dim i As Long
Dim i As Integer
ThisWorkbook.Worksheets("Costings").Activate
Range("A11:P770").Select
Selection.ClearContents
LR = Sheets(SHEETNAME).Range("CC" & Rows.count).End(xlUp).Row
For i = 11 To 769
If Sheets(SHEETNAME).Range("M" & i).Value = "Yes" Then
Do Until Sheets("Costings").Cells(MyRow, MyCol).Value = "" Or MyRow > 770
MyRow = MyRow + 1
Loop
If MyRow <= 770 Then
Sheets("Costings").Cells(MyRow, MyCol).Value = Sheets(SHEETNAME).Range("A" & i).Value
MyRow = MyRow + 1
MsgBox "You have ran out of room. Some entries were not copied"
Exit For
