Consolidate Multiple Rows with Match FirstName,MiddleName and LastName with a Unique ID Number
Change this...
.Cells(i, 1) = Sheet4.Cells(Application.Match(m, Sheet4.Columns(5), 0), 1) & "-" & .Cells(i, 4)
Be remember, there is no error handling in the macro. You may add the same as need or something like this.
on error resume next
or
on error goto Err
Err:'add before end sub
  • Like
Reactions: pab
Change this...
or
on error goto Err
Hi Sir,
it showed an erroneous data -
it should be the NEW GENERATED KEY found @ Pre Generated CIF plus BRANCH CODE @ Branch 1 to 30.
Sample:
00001 - 0001
00011 - 0002
Thanks,
Hi Sir,
Sample:
00001 - 0001
00011 - 0002
Thanks,
Hi Sir,
The NEW CIF should be a combination of New Generated Key found @ Pre Generated CIF WS PLUS the BRANCH CODE located on every Branch WS.
Thanks,
What do you mean by "BRANCH CODE located on every Branch WS."
Is this sheet name digit or col C value or something else.
Hi Sir,
If you can see there is a branch code on every Branch Worksheet e.g. Branch 1 , Branch 2. u will add that to the NEW CIF CODE found at the PRE GENERATED CIF WORKSHEET.
Thanks,
Hi Sir,
Thanks,
Hi Sir,
On every BRANCH WORKSHEET there is a BRANCH DATA e.g.0001,0011 etc. that value will be added on the matching NEW GENERATED KEY found @ Pre Generated CIF worksheet.
It will be
BRANCH+NEW GENERATED KEY
0001-00003
Thanks,
.Cells(i, 1) = .Cells(i, 4) & "-" & Sheet4.Cells(Application.Match(m, Sheet4.Columns(5), 0), 1)
