Conditional formatting with color coding is not working
I have a requirement to highlight the cells meeting a condition across and within two sets of 10 (Rows) x 6 (Columns) for two different scenarios. The formula i have used is working for one scenario but it is not working for the other one.
Issue
> The similar formula is working for Scenario 1 and it is not working for Scenario 2
> The formula is just comparing the cells across the sets and not within the set
Requirement:
> The formula or script should identify the pair of numbers with same output within the set and outside the set as in above examples
> The matching cells should be highlighted with same color
Please check the attached workbook for all details including the formulas and examples.
Kindly assist...!!
vletm
maniniinfotech
Kindly assist...!!
Kindly follow Forum Rules, which are for You too
is there any other means of showing the details , not able to explain the requirement n can i post any video or any screen sharing option so that i can explain
its not the problem of conditional formatting
it should highlight the cells which are related or relative to each other
then only the cells should be highlighted
i have tried to show the example in the attachment kindly go through the attachment
for grid 1 and 2 i have explained
grid 3 and 4 are not working as grid 1 and 2
