Conditional formatting - Changing colour of a group of cells
Trace
I have a roster in which I need to highlight 4 cells if certains times are selected.
Eg.
If
G11 = 16:00
and if
I11 = 22:00
and if
G14 = 6:00
and if
I14 = 8:00
then I want these to be the one colour.
Can anyone please help!
@Trace,
Select all the 4 cells,
Go to CF, write this rule
=AND(G11=16:00,I11=22:00,g14=6:00,i14=8:00)
and set the color as you want.
Thank you Chandoo but unfortunately this doesn't work for me :|
Does it matter if my cells are drop down data? Or that they're in time format?
Hi Trace ,
Try using =TIME(16,00,00) , =TIME(22,00,00) , =TIME(6,00,00) and =TIME(8,00,00) in the AND formula , instead of just 16:00 , 22:00 , 6:00 and 8:00.
Hi Trace ,
I tried this on my PC and it works , if you format one cell at a time !
Select conditional formatting for G11 and enter the following formula :
=AND(G11=TIME(16,0,0),I11=TIME(22,0,0),G14=TIME(6,0,0),I14=TIME(8,0,0))
Copy the above formula for the conditional formatting in I11 , G14 and I14 individually. It works.
Damn! That works!! Long process but at least it works!
Thank you so much!
I love this website *hugs*
