Code does Work for MS 2016 but not 2019
LearnExcel&VBA
Hi i have below code i am using this on excel 2016 it is working fine but when run this code on 2019 it does not work.
Sub Exce20192016()
Dim xFd As FileDialog
Dim xFdItem As Variant
Dim xFileName As String
Set xFd = Application.FileDialog(msoFileDialogFolderPicker)
If xFd.Show = -1 Then
 xFdItem = xFd.SelectedItems(1) & Application.PathSeparator
 xFileName = Dir(xFdItem & "*.csv*")
 Dim xCount As Integer
 xCount = Application.InputBox("Number of Rows", "Kutools for Excel", , , , , , 1)
 Do While xFileName <> ""
 With Workbooks.Open(xFdItem & xFileName)
 Dim I As Long
LableNumber:
If xCount < 1 Then
GoTo LableNumber
For I = Range("A" & Rows.CountLarge).End(xlUp).Row To 2 Step -1
Rows(I).Copy
Rows(I).Resize(xCount).Insert
 xFileName = Dir
 Loop
Dim wb As Workbook
 For Each wb In Workbooks
 wb.Close SaveChanges:=True
 Next wb
Chihiro
Be patient, we are volunteers and it hasn't even been a day since you posted your question.
As for your question... There's nothing that changed between Excel 2016 to 2019 that would break the code.
Likely cause is your environment (OS, folder permission etc) or some other factor such as add-in interfering with the code.
Chihiro
Like I stated. If the code worked in Excel 2016, there's nothing that would prevent it from running on Excel 2019. There must be something else that's impeding code execution.
