Chart axis format max min values
me yu
I need to be able to set the max and min values of a chart automatically so that the chart area is 1% above the max data value and 1% below the min data value.
Any help greatly appreciated.
Check this out:
http://peltiertech.com/Excel/Charts/AxisScaleLinkToSheet.html
Method describes how to link to a cell, and you could easily write a a formula to calculate max value of your data + 1%.
Me Yu
Firstly, Welcome to the Chandoo.org forums.
In addition to using the techniques which Luke linked to above
You can also use another technique that doesn't involve VBA
Add two sets of data to each chart
The two sets will be calculated values and will be the Minimum and Maximum values for each chart based on the data for the charts
You can add +/- 1% to the data if you wish
Then add 2 series to each chart and set the series to have no line color and no markers
Make sure the Y Axis are set to Automatic Min/Max scale
You can also use this technique to set a common set of data across multiple charts
Just setup the Min/Max data to be the Min/Max of all the charts data
All done without VBA
