Challenging questions on vlookup and index match
rohan jha
Dear All,
Please look the excel first.
Now in a column i have the "Values" and i have to fetch the name. So the look up value is 22 and the name that i need to fetch is "A".
But as 22 is used twice, the vlookup is always fetching "A". What i need is that first time it should return A while next time it should search and then return "F".
Please suggest a solution.
Rohan
I assume you want this as an answer:
In G2:
=IF(COUNTIF(A:A,$E$2) < ROWS($E$2:E2),"",INDEX(B:B,SMALL(IF($A$2:$A$8=$E$2, ROW( $A$2:$A$8)),ROW(A1)))) Ctrl+Shift+Enter
Then Copy G2 down
You can read about how this works here:
http://chandoo.org/wp/2011/11/18/formula-forensics-003/
See your sample file below:
Another non-array formula option.
Using Hui's table, in G2, formula Copy down :
=IFERROR(INDEX(B$2:B$8,MATCH(0,INDEX(COUNTIF(G$1:G1,B$2:B$8)+(A$2:A$8<>E$2),0),0)),"")
Bosco
Bosco
My table in G2:G10 isn't a fixed Table
It is the answer to Rohan's original question
That is, it is the values in column B that match when Column A = E2 = 22
Bosco
Hi Hui,
My formula returned result as same as yours.
Maybe this part…(A$2:A$8<>E$2)… made difference from your formula....(A$2:A$8=E$2)...
In fact, the formula comprised with Remove Duplicate formula (Red) + Conditional matching (Blue)
The Conditional matching part is : ….(A$2:A$8<>E$2)….
Then, how does it work ?
1] .....(A$2:A$8<>E$2)….. return {FALSE;TRUE;TRUE;TRUE;TRUE;FALSE;TRUE} ….. >> {0;1;1;1;1;0;1}
>> A$2:A$8<>22 (un-matching) return FALSE (0),
and, A$2:A$8=22 (matching) return TRUE (1)
2] …..MATCH(0,INDEX(COUNTIF(G$1:G1,B$2:B$8)+
(A$2:A$8<>E$2),0),0) …..>>
>> ….MATCH(0,{0;1;1;1;1;0;1},0) …..>>
and 0 inside the Lookup array {0;1;1;1;1;0;1} become the marching value in respect of the MATCH Lookup criteria 0.
>> Return 1
3] =IFERROR(INDEX(B$2:B$8,MATCH(0,INDEX(COUNTIF(G$1:G1,B$2:B$8)+(A$2:A$8<>E$2),0),0)),"") …..>>
>> =IFERROR(INDEX(B$2:B$8,1),"") …..>>
>> Final return "A"
Bosco
