Can you help me with ListBox Code Please?
Just one last thing. The ListBox called LB_00 displays all data stored in worksheet "Data". Data Worksheets stores all information in a chronological order(Which I love it remains like that). And LB_00 shows me the same information in the same chronological order. I'd love that LB_00 to shows the last entry on top of it. So, I´d love that the last entry to be shown on top of the ListBox. DATA worksheet will remain as it is, but in the ListBox “LB_04”, the last data stored must be shown above. Can it be possible.
Thank you so much.
  • Sebastian Data Entry (guests V2).xlsb
Question...Is there a way to keep the "Reverse Order Checkbox", Chb_01, checked automatically "Checked" all the time as default? I searched on internet on how to do it.
    T_00.Value = WorksheetFunction.Max([NBRs]) + 1
    T_01.Value = Format(Now, "mm/dd/yyyy hh:mm AM/PM")
    T_03.List = [rooms_tbl].Value
    Cmd_00.Enabled = True
    Cmd_01.Enabled = False
    Cmd_04.Enabled = False
With LB_00
    .List = [Data_Tabl1].Value
    .ColumnCount = [Data_Tabl1].CurrentRegion.Columns.Count
    .ColumnWidths = "40;90;80;40;190;100;90;50;40;90;100"
    For i = 0 To .ListCount - 1
        .List(i, 1) = Format(.List(i, 1), "mm/dd/yyyy hh:mm AM/PM")
        .List(i, 6) = Format(.List(i, 6), "mm/dd/yyyy hh:mm AM/PM")
        .List(i, 9) = Format(.List(i, 9), "mm/dd/yyyy hh:mm AM/PM")
Load_Listbox
Me.EnableEvents = True
T_03.SetFocus
T_00.BackColor = vbWhite
Chb_01 = True 'To automatically keep checked the Reserve Order on
When userform opens, "Chb_01 = True" works perfectly, but when a add a new request, update a request, delete a request, Print, or click on "Reset", Chb_01 keep checked but the order of listbox LB_00 changes. Is there a way to keep it as reverse order, no matter if I Add New, Update, Reset, Delete, or Print?
Thank you in advace again.
You are the best.
  • Sebastian Data Entry (reverse).xlsb
Never Mind...I found about how to do it. What I did was jus add this little code: Chb_01 = False before in the corresponding CommandButtons. "Chb_01 = False" to uncheck and then "Chb_01 = True" to check again, so it works perfectly. I said to myself, what about if I uncheck and then check again?. Lucky shot. Thank you so much for everything.
You are the best Belleke.
Changing the Reset sub like this is enough.
Sub reset()
For Each Ctrl In Controls
    If TypeName(Ctrl) = "TextBox" Or TypeName(Ctrl) = "ComboBox" Then Ctrl.Value = ""
    If TypeName(Ctrl) = "CheckBox" Then Ctrl.Value = False
Next Ctrl
With LB_00
Chb_01 = True
Is there a way to set a watermark in the middle of a Textbox? I´d love to display "Type to Search" in the middle of the TextBox. Is this possible?
