I am still trying to get this sheet working , what i need to do is use a macro with a button to activate it to copy cells c18 to e36 to cells bj22 to bl41 , i don't know how to do the macro and need help .
Do you want to do a save or save as , if it is just save u do not need a macro. Can you explain more what you want to achieve here , if the excel is having a in-built functionality it is better to use it rather than writing a macro...
Then you can use the default save function , just save your workbook as macro enabled workbook and enable the content whenever you open the workbook to run the macro
