Hello!
Im looking into PowerPivot and building a few simple databases. I've been making a few VBA scripts collecting data from various reports and sources to build my own little data warehouse.
Having never really done this before Im stuck on a question regarding the "theory" of building a database. What is the best way to do it? Which way is better in regards to use with Pivot, PowerPivot without taking up too much computing power.
Look at these Examples:
1,
Period Product Type Amount
130630 Banana Cost -1
130630 Banana Sales 2
130630 Apple Cost -3
130630 Apple Sales 45
130630 Oranges Cost -156
130630 Oranges Sales 687
2,
Period Product Cost Sales
130630 Banana -1 2
130630 Apple -3 45
130630 Oranges -156 687
I want to use the first example since I find it easier to have one column with the same type of data in it. If I want thet result for apples I can just sum all rows with apple. But the first example has twice as many cells as number two. Im thinking after a few hundreds of thousand rows this will be too much. And I can make calculated fields in pivot to calculate the net result for me. Note that these are examples. IRL Cost and Sales would probably be 15 different things, so 15 columns or x15 rows. Then again PowerPivot is great with handling massive amounts of rows and data
Im looking to this forum for some help on how to think about this. Anyone know a good book where I can read up on the theory behind building databases like this? Any special blogs I should read? Whitepaper? If you had the above examples, what would you do?
1,
2,
130630 Banana -1 2
130630 Apple -3 45
