I have a workbook with imput datasheet and Product database .
Using index and match vba code as below.
however due to change in format , the columns have move in both sheets imput and product database .
Looking assistance for help to change the code according the columns No
in the amended sheet column file.
I have attached the original one testxlsm and the amended xlsm which is the one in which the columns no have be moved .
in the amended sheet format
The original lookup in the third column reference imput data and extract as per reference data in product database that is column A and Column B of product database.
thanks if someone can assist
Sub M1()
Dim x As Long
Dim arr() As Variant
Dim temp As Variant
Dim ws1 As Worksheet
Dim ws2 As Worksheet
Dim dic As Object
Const delim As String = "|"
Set ws1 = Sheets("Input Datasheet")
Set ws2 = Sheets("Product DataBase ")
Set dic = CreateObject("Scripting.Dictionary")
With ws2
For x = 1 To .Cells(.Rows.Count, 3).End(xlUp).Row
dic(Val(.Cells(x, 3).Value)) = .Cells(x, 1).Value & delim & .Cells(x, 2).Value
Next x
With ws1
x = .Cells(.Rows.Count, 3).End(xlUp).Row
arr = .Cells(2, 1).Resize(x - 1, 4).Value
For x = LBound(arr, 1) To UBound(arr, 1)
If dic.exists(.Cells(x + 1, 3).Value) Then
temp = Split(dic(.Cells(x + 1, 3).Value), delim)
arr(x, 1) = temp(0)
arr(x, 2) = temp(1)
Erase temp
arr(x, 1) = Empty
arr(x, 2) = Empty
Next x
.Cells(2, 1).Resize(UBound(arr, 1), UBound(arr, 2)).Value2 = arr
Set dic = Nothing
Set ws1 = Nothing
Set ws2 = Nothing
Erase arr
