Array (Fast Read, Make Changes in array and Paste values Again)
Base 0 = LBound(Array) = Count begins from 0
Base 1 = LBound(Array) = Count begins from 1
So when you define array size as 1 in default case it means two rows or two columns depending on the dimension. So after making it option base 1 the dimension matches correctly.
It is not really the dimension but the sizing the array when you are ReDim-ing. You are arriving LRow which is last row (138) and therefore Array will have 138 elements. At the end of code it will have 137 rows populated and one empty row. So your dimension reference has to be correct.
So following code will work.
Option Base 1
Sub LearnArray()
Dim BrandModel() As Variant
Dim Brand() As Variant
Dim Model() As Variant
Dim x, Lrow As Long
If WorksheetFunction.CountA(Cells) > 0 Then
Lrow = Cells.Find(What:="*", After:=[A1], SearchOrder:=xlByRows, SearchDirection:=xlPrevious).Row
BrandModel = Sheet1.Range(Cells(2, 1), Cells(Lrow, 1)).Value
ReDim Brand(1 To UBound(BrandModel), 1) '// Notice it takes limit from
ReDim Model(1 To UBound(BrandModel), 1) '// BrandModel array size
For x = LBound(BrandModel) To UBound(BrandModel)
Brand(x, 1) = Left(BrandModel(x, 1), InStr(BrandModel(x, 1), " "))
Model(x, 1) = Replace(BrandModel(x, 1), Brand(x, 1), "")
Next x
Sheet1.Range(Cells(2, 3), Cells(Lrow, 3)).Value = Brand
Sheet1.Range(Cells(2, 4), Cells(Lrow, 4)).Value = Model
Dear Shrivallabha,
If you please take a look at my new thread and help me there because you are more into my understanding of Arrays. Please..Thanks a lot Again.
