Activate/deactivate MsgBox based on Combo Box value
I have a userform and the following code notifies users if the sales proposal is current or expired. It works fine. Once the order is completed, I don't want these messages to keep popping up. So I need to add a condition based on the value (stage) in a combo box.
I want the messages to be 'disabled' if the stage selected in the combo box is Completed or Canceled.
txtExpDate = expiration date (proposal date + 60 days)
txtPropDate = proposal date
txtPORecDate = PO received date
cboStage = combo box list: Waiting to Process, Waiting for PO, Waiting Approval, Standby Completed, Canceled
I've been wrestling with this and no luck. I'm still new to VBA.
Thank you in advance for your consideration.
'***Expiration Date***
Dim x As Date
Dim y As Date
    If IsDate(DateValue(txtPropDate.Value)) Then
            txtExpDate.Value = DateValue(txtPropDate.Value) + (60)
            txtExpDate.Enabled = False
            x = DateValue(txtPropDate.Value) + (60)
            y = DateValue(txtPORecDate.Value)
   With txtExpDate
    If x < y Then
            MsgBox "This proposal is expired. Requires management approval or an updated proposal."
            txtExpDate.BackColor = vbYellow
    ElseIf x >= y Then
            MsgBox "This proposal is current. Proceed with order entry."
            .BackColor = 12648384
Ok, I went back and identified the list index for each stage as follows:
StageList Index
Waiting to Process0
Waiting PO/Quote Revision1
Waiting Approval2
Standby3
Completed4
Canceled5
Here is my code, but the messages are still popping up if the Stage is Completed or Canceled. This sub is larger than I've included. Is saying 'Exit Sub' appropriate since I want it to continue onto the next line of code, not the next Private Sub?
Private Sub UpdateandSaveOrder_Click()
Dim x As Date
Dim y As Date
  With txtExpDate
    If x < y Then
    ElseIf x >= y Then
            .BackColor = &HFFFFC0
  With cboStage
   If cboStage.ListIndex > 3 Then Exit Sub
UPDATE: I had to remove this code it seemed to 'break' other lines that were working fine before. Back to the drawing board...
