Sums of multiple rows through Offset
game_federer
Hi all,
I have that contains sales data for a product P1, P2 or P3 from January to July. Suppose we enter a month and a product into our worksheet. Please help me with a formula using OFFSET that will give the total sales of that product in the given month
  • Question.xlsx
It is possible to use OFFSET but I would suggest settling for INDEX in this case.
= SUMIFS( INDEX( sales, 0, MATCH( specifiedMonth, months, 0 ) ),
Product, specifiedProduct )
The part of the formula highlighted in magenta is a reference to the sales column corresponding to the specified month. From there your SUMIFS will work fine and is computationally efficient.
  • Question (pb).xlsx
Try,
In C16, enter :
=SUMIF(A$2:A$10,A16,INDEX(B$2:H$10,0,MATCH(B16,B$1:H$1,0)))
Or,
if you wanted to use OFFSET(), try this :
=SUMIF(A$2:A$10,A16,OFFSET(A$1,1,MATCH(B16,B$1:H$1,0),9))
Bosco
  • Question(sumif).xlsx
Another way to do without using OFFSET()
=SUMPRODUCT(($A$2:$A$10=$A$16)*($B$1:$H$1=$B$16)*(B2:H10))
Decio
Hi Decio,
1] In compare with these 2 formulas :
2] This part of formula (highlighted red) is to return the Sum Range
* LOOKUP function is always faster than Mathematic calculation
3] Using a VBA Timer in testing of the above formulas
Iterations = 100000
SUMIF+INDEX took 4.67 seconds
SUMPRODUCT took 6.64 seconds
So,
SUMIF+INDEX is faster than SUMPRODUCT around 30% in this example
Bosco
Hi Decio,
Iterations = 100000
So,
Bosco
Thank you sir for your comprehensive replies.
Really appreciated!
The timing differences will increase steadily as the number of months under consideration grows.
There is also a time penalty to be paid for my preferred use of Names (small) and array formulas (noticeable) but those are costs I gladly incur to improve formula transparency and to help control errors.
