Hello, I have some tool to work to comprae cuplicates and mark if exist by the one cell.
Now I need compare workbook from 2 column (creating string from 2 column)
How it should be work:
If I wrote in A = nothing
If I wrote in A and B smg it should automatickly find duplicates in workbook and mark on color.
also I'd like to looking for duplicat in for 2 ranges in worksheets in all workbook.
Sheet1:AB
Sheet1 PR
Sheet2:AB
Sheet2 PR
and so on:
first loop starts looking for match in AB then PR , AB , PR... the same value.
That's the one tool from 1 column what i use from workbook.
Also usefull will if it separete if it was founding in activesheet or othersheet.
1st code it's not sorking for duplicates in activesheet
2nd code (marks on 3 colors depends of scenerio.
Sheet1:AB
Sheet1 PR
Sheet2:AB
Sheet2 PR
and so on:
Private Sub Workbook_SheetActivate(ByVal Sh As Object)
Dim lRow As Long, wsLRow As Long, i As Long
Dim aCell As Range
Dim ws As Worksheet
Dim strSearch As String
With Sh
'~~> Get last row in Col A of the sheet
'~~> which got activated
lRow = .Range("A" & .Rows.Count).End(xlUp).Row
'~~> Remove existing Color from the column
'~~> This is to cater for any deletions in the
'~~> other sheets so that cells can be re-colored
.Columns(1).Interior.ColorIndex = xlNone
'~~> Loop through the cells of the sheet which
'~~> got activated
For i = 1 To lRow
'~~> Store the ID in a variable
strSearch = .Range("A" & i).Value
if strSearch <> "" then 'eliminated color empty cell
'~~> loop through the worksheets in the workbook
For Each ws In ThisWorkbook.Worksheets
'~~> This is to ensure that it doesn't
'~~> search itself
If ws.Name <> Sh.Name Then
wsLRow = ws.Range("A" & ws.Rows.Count).End(xlUp).Row
'~~> Use .Find to quick check for the duplicate
Set aCell = ws.Range("A1:A" & wsLRow).Find(What:=strSearch, _
LookIn:=xlValues, _
LookAt:=xlWhole, _
SearchOrder:=xlByRows, _
SearchDirection:=xlNext, _
MatchCase:=False, _
SearchFormat:=False)
'~~> If found then color the cell red and exit the loop
'~~> No point searching rest of the sheets
If Not aCell Is Nothing Then
Sh.Range("A" & i).Interior.ColorIndex = 3
Exit For
Next ws
End if
'code created by user3598756
Dim IDsRng As Range, IDCell As Range
Dim ws As Worksheet
Dim foundInOtherSheet As Boolean, foundInActiveSheet As Boolean
With Sh
Set IDsRng = .Range("A1", .Cells(.Rows.count, 1).End(xlUp)) '<--| set the IDs range as all column A not empty cells with some "text" content
'~~> This is to cater for any deletions in the other sheets so that cells can be re-colored
For Each IDCell In IDsRng '<--| Loop through ID cells (i.e. column A "text" cells of the activated sheet)
strSearch = IDCell.Value
foundInActiveSheet = WorksheetFunction.CountIf(IDsRng, strSearch) > 1 '<--| count possible dupes in active sheet
foundInOtherSheet = False '<--| initialize it at every new ID
'~~> This is to ensure that it doesn't search itself
With ws
foundInOtherSheet = WorksheetFunction.CountIf(.Range("A1", .Cells(.Rows.count, 1).End(xlUp)), strSearch) > 1
If foundInOtherSheet Then Exit For '~~> If found then color then no point searching rest of the sheets
Select Case True '<--| now act accordingly to where duplicates have been found
Case foundInOtherSheet And Not foundInActiveSheet '<--| if duplicates found in "other" sheets only
IDCell.Interior.ColorIndex = 3 '<--| red
Case foundInOtherSheet And foundInActiveSheet '<--| if duplicates found in "other" sheets and in "active" one too
IDCell.Interior.ColorIndex = 6 '<--| yellow
Case Not foundInOtherSheet And foundInActiveSheet '<--| if duplicates found in "active" sheets only
IDCell.Interior.ColorIndex = 14 '<--| green
End Select
