Dear Sir,
If dealer has done business in a month as per sale amount in (excel sheet),
The Payout % to be derived based on total volume and discounts given.
There is a grid of volume / discount & product
Please help with the formula
John
Dear Sir,
John
Hi tried
Following formula
=INDEX(Rate!$D$6:$J$23,MATCH(F5,Rate!$D$6:$D$23,0),MATCH(H5,Rate!$D$6:$J$6,0)) rate doesn't match in case of disc & should be 0% in case discount exceed
attached file for reference
Hi Khalid,
Thanks for revert
Tried =INDEX(Rate!$D$6:$J$23,IF(OR(F5="A",F5="E"),MATCH(F5,Rate!$D$6:$D$23,0)+IF(F5="A",IF(E5<=50,0,IF(E5<=60,1)),IF(E5<=65,0,IF(E5<=75,1))),MATCH(F5,Rate!$D$6:$D$23,0)),MATCH(H5,Rate!$D$6:$J$6,0)) but still not working desired result
1. What are the elements of data in your workbook ; what are the roles played by each element ; in your case , what is the function of data in the range A6:B79 , D6:J23 in the Rate tab , and A4:I3885 in the Data tab ?
2. In which cells in which tab do you want formulae ?
3. What should these formulae return , and what should their output be based on ?
4. Work out a few examples with as much of variation as possible i.e. if you work out 2 examples , both of them dealing with amounts in the range 2 lakhs to 10 lakhs , it will not give as clear a picture as if you work out 5 or more examples , with each amount from a different slab.
If you take the trouble to do all of the above , I can guarantee that you will get an answer within 2 hours.
Thanks for your revert Mr. Narayan,
Explaining to understand more about the workbook
we are distributing payout to dealers,
There is a Payment Slab of 2L to 10L, 10L to25L.....
Product bifurcated as A,B,C,D.................
Specific amount of commission is pre-decided as per product, every dealer is bifurcated as per codes and as per their performance in sale payout is given.
In few products there is discount grid mentioned if discount exceeds % to be 0%
John
1. What are the elements of data in your workbook ; what are the roles played by each element ; in your case , what is the function of data in the range A6:B79 , D6:J23 in theRate tab , and A4:I3885 in theData tab ?
è A6:B79 , D6:J23 in theRate tab – it is % grid given to dealers as per sale, A4:I3885 in theData tab – in this data product, sale amount etc given
è Cell No. G5 require formula
è Formulae should return % as per rate chart & if discount exceed 0%
Examples already tried one formula its working but issue in case of discount Please check earlier attachment
