Macro comparing cells in sense inverse and counting until criteria is met
Luis Ramirez
Hello Guys,
I am looking for a macro a bit difficult, at least to my expertise level. I have a column with values:
A1. 100
A2. 98
A3. 19
A4. 134
A5. 234
A6. 21
Then I need to compare each cell with previous one (let´s say A6 with A5) IF the value is minor then continue to compare with next previous next one (A6 with A4 in this case). And continue to do it until the value is greater (in this case until A3). A counter must show up the number of cells that met the criteria (in this case 2, A5 and A4).
If someone can put me on the right track will be really great!
Hi Luis,
Try below code,
Sub counterTest()
Dim lr As Long
Dim cntr As Long
cntr = 0
lr = ActiveSheet.Cells(Rows.Count, 1).End(xlUp).Row
For i = lr - 1 To 1 Step -1
    If Cells(lr, 1) <= Cells(i, 1) Then
        cntr = cntr + 1
    Exit For
MsgBox cntr
Hi Luis,
In the above macro you can change the code
To
lr = ActiveCell.Row
This will work based on the cell which you have selected
Thanks Somendra and Sathish,
You are very good. Actually what I need is that automatically goes through range A1:A6 (or whatever range) and verify cell by cell, and if it is greater than the previous one, continue with the next one, counting until this criteria is no longer met. So at the end I should have a list like this:
A1. 100 0
A2. 98 1
A3. 19 2
A4. 134 0
A5. 234 0
A6. 21 2
Taking the code of Somendra, I tried this:
Sub counterTest()
Dim lr As Long
Dim cntr As Long
Dim n As Long
cntr = 0
For n = 2 To lr Step 1
If Cells(n, 1) <= Cells(n - 1, 1) Then
For i = n - 1 To 1 Step -1
If Cells(n, 1) <= Cells(i, 1) Then
cntr = cntr + 1
Exit For
ActiveSheet.Cells(n, 2) = cntr
ActiveSheet.Cells(n, 2) = 0
Next n
Nevertheless, I can not get the counter to work properly.
I tried other codes, using the FOR cycle first, but it did not work. You already have put in the right track guys, so if you have any additional inside, it will be great. And really thanks.
Luis
Hi Luis ,
Can you see whether this works ?
Public Sub Insert_Counter()
          Dim Number_of_rows As Long
          Number_of_rows = [List].Rows.Count
          For Each cell In [List]
              If cell.Row = [List].Row Then
                  cell.Offset(0, 1).Value = 0
                  i = 1
                  counter = 0
                  Do While cell < cell.Offset(-i).Value
                    counter = counter + 1
                    i = i + 1
                    If cell.Offset(-i).Row < [List].Row Then Exit Do
                  Loop
                  cell.Offset(0, 1).Value = counter
@Luis Ramirez
Here another option:
Sub counterTest()
Dim lr As Long
Dim cntr As Long
cntr = 0
For j = lr To 1 Step -1
    For i = j - 1 To 1 Step -1
    If Cells(j, 1) <= Cells(i, 1) Then
        cntr = cntr + 1
    Exit For
    Cells(j, 2) = cntr
    cntr = 0
Next j
